Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 2
Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder. Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and above and below the SD card slot cover. Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
  • Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder.
  • Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and above and below the SD card slot cover.
  • Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
Insertar traducción aquí
