Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Make sure the device is powered off. Gently insert a spudger into one of the bottom corners between the screen and body case.
  • Make sure the device is powered off.
  • Gently insert a spudger into one of the bottom corners between the screen and body case.
  • Slide the spudger along the inside of the crack in order to pry the case open.
  • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
Insertar traducción aquí
