Saltar al contenido principal
Inglés
Español
Paso 4
Using the wire stripper, strip the ends of each wire approximately 1-2 cm  to reveal enough wire to twist back together with new motor's wires. Next, using the wire cutter, cut the {Positive & Negative} wires that are heading from the Coil Assembly  to the  Attached power cord. Cut approximately half way between the two ends of both wires.
  • Using the wire stripper, strip the ends of each wire approximately 1-2 cm to reveal enough wire to twist back together with new motor's wires.
  • Next, using the wire cutter, cut the {Positive & Negative} wires that are heading from the Coil Assembly to the Attached power cord. Cut approximately half way between the two ends of both wires.
  • Reminder: Be sure to keep track of the corresponding wires and their locations to match when you insert the new motor.
  • After you cut the old Coil Assembly's wires, remove it completely, and replace it with new one.
Insertar traducción aquí
