Saltar al contenido principal
Inglés
Español
Paso 2
Lift the switch assembly up to loosen the actuating arm. Pull switch button away from actuating arm. Then unclip the actuating arm from the switch assembly. Locate the switch insulation underneath the switch assembly.
  • Lift the switch assembly up to loosen the actuating arm.
  • Pull switch button away from actuating arm. Then unclip the actuating arm from the switch assembly.
  • Locate the switch insulation underneath the switch assembly.
  • Note: The switch insulation is fragile and thin. Be careful not to damage it.
Insertar traducción aquí
