Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Caution: Make sure the clippers are unplugged from any electrical outlets before beginning teardown. Using the Philips screwdriver, unscrew the two housing cover screws indicated. using the Philips screwdriver, unscrew the two mounting screws indicated, holding down the Coil Assembly.
  • Caution: Make sure the clippers are unplugged from any electrical outlets before beginning teardown.
  • Using the Philips screwdriver, unscrew the two housing cover screws indicated.
  • using the Philips screwdriver, unscrew the two mounting screws indicated, holding down the Coil Assembly.
  • Reminder: keep track of appropriate washers with each screw
  • Using the Philips screwdriver, remove the switch installment screw indicated.
Insertar traducción aquí
