Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 11 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board. De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
  • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
  • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
  • When reconnecting the antenna wire be VERY certain that the round connector at the end of the wire is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connector.
Insertar traducción aquí
