Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 8
Paso 8
Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna. Remove the speaker enclosure assembly. Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
  • Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
  • Remove the speaker enclosure assembly.
  • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
  • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
Insertar traducción aquí
