Saltar al contenido principal
Inglés
Español
Paso 18
Alas, the last piece of the teardown puzzle—the Lightning connector assembly. This time around, the Lightning connector assembly brings us everything we've seen before  and then some, with the addition of a second microphone. This assembly is convenient as a space-saving measure, but it has a nasty side effect—repairing a single damaged Lightning port or headphone jack requires replacing the entire assembly.
  • Alas, the last piece of the teardown puzzle—the Lightning connector assembly.
  • This time around, the Lightning connector assembly brings us everything we've seen before and then some, with the addition of a second microphone.
  • This assembly is convenient as a space-saving measure, but it has a nasty side effect—repairing a single damaged Lightning port or headphone jack requires replacing the entire assembly.
Por desgracia, la última pieza del rompecabezas desmontable: el ensamblaje del conector Lightning.
Esta vez, el ensamblaje del conector Lightning nos trae todo lo que hemos visto antes y algo más, con la adición de un segundo micrófono.
Este conjunto es conveniente como medida para ahorrar espacio, pero tiene un efecto secundario desagradable: reparar un solo puerto Lightning dañado o un conector para auriculares requiere reemplazar todo el ensamblaje
