Saltar al contenido principal
Inglés
Español
Paso 11
The next stage of the game involves removing the logic board. With the skill of a blackjack dealer, we send the cards cables flying and boards flipping. You're going to need to channel your inner card shark to get this logic board out. Removing the final connector requires you to flip the logic board over—not a big problem, but a bit annoying.
  • The next stage of the game involves removing the logic board.
  • With the skill of a blackjack dealer, we send the cards cables flying and boards flipping.
  • You're going to need to channel your inner card shark to get this logic board out. Removing the final connector requires you to flip the logic board over—not a big problem, but a bit annoying.
  • We shuffle the logic board out of the case for a closer look. We like to have lots of chips on our (teardown) table...
La próxima etapa del juego es remover la placa lógica.
Con la habilidad de un repartidor de cartas de blackjack, arrojamos los cables y placas.
Vas a tener que canalizar tu tiburón de cartas interno para poder remover esta placa lógica. Remover el conector final requiere que voltees la placa lógica, lo que no es un gran problema pero es un poco molesto.
Barajamos la placa lógica fuera de la caja para verla más de cerca. No gusta tener muchos chips en la mesa (de desmontaje).
