Saltar al contenido principal
Inglés
Español
Paso 2
It’s finally time to see what this revolutionary new iPhone has in store for us. At a glance, the 6s is the spitting image of its older sibling, but there's a lot more to it than meets the eye. Here's some of what's under the hood: Improved Touch ID home button
  • It’s finally time to see what this revolutionary new iPhone has in store for us.
  • At a glance, the 6s is the spitting image of its older sibling, but there's a lot more to it than meets the eye. Here's some of what's under the hood:
  • Improved Touch ID home button
  • 5 MP FaceTime HD Camera
  • Retina HD Display with 3D Touch
  • Laid out side-by-side, there are few notable differences between the two—sans the new Rose Gold enclosure.
  • Upon closer inspection, the 6s is a hair larger than the 6 (138.3 x 67.1 x 7.1 mm vs. 138.1 x 67.0 x 6.9 mm), and it's stamped with a new model number: A1688.
  • The 6s has also packed on a bit of weight when compared to its older sibling, weighing in at 143 grams vs. the 6's 129 grams.
Es finalmente hora de ver lo que este nuevo iPhone revolucionario tiene guardado para nosotros:
A primera vista, el 6s es el vivo retrato de su hermano mayor, pero hay más de lo que podemos ver. Aquí te mostramos lo que esconde:
Botón de Inicio y ID Táctil mejorado
Cámara de 5 MP HD FaceTime
Pantalla Retina HD con 3D Touch
Puestos lado a lado, hay diferencias notables entre los dos —sin la nueva carcasa Rosa Dorado.
Al inspeccionarlo más de cerca, el 6s es un poquito más grande que el 6 (138,3 x 67,1 x 7,1 mm vs. 138,1 x 67,0 x 6,9 mm) y está estampado con un número nuevo de modelo: A1688.
El 6s lleva además algo más de peso si se lo compara con su hermano mayor, pesando 143 gramos en vez de los 129 gramos del 6.
