Saltar al contenido principal
Inglés
Español
Paso 6
If possible, test on a known good system first. Improving the read percentage: If you are not happy with the results, keep adjusting the motor. Repeat until you are happy with the passing read rate, or the motor doesn't spin.
Test the repaired system
  • If possible, test on a known good system first.
  • Improving the read percentage: If you are not happy with the results, keep adjusting the motor. Repeat until you are happy with the passing read rate, or the motor doesn't spin.
  • If you see the Insert PlayStation CD-ROM screen, the motor is running slow. Adjust the speed to be faster.
  • Partially reassemble the system and test it. If it is sufficient, reassemble the system.
  • To test the read percentage, get a few known good games and see which ones load. A minimum of 5 test games is recommended. Only adjust the laser again after each full test is done.
  • If the game loads, test play the system for a few minutes to check the stability. Important: Some early revisions have FMV issues - THIS IS EXPECTED.
Insertar traducción aquí
