Saltar al contenido principal
Inglés
Español
Paso 5
Only adjust it enough to reliably read games and music CDs again. If the speed is too slow, the laser can physically "burn" your games or kill the laser. Consider anything less then a 80-90% read rate a failure. These are hard to reliably recover. Before starting, mark the original adjustment point and write down the factory setting as tested. It will be difficult to take it back to stock without this information.
Adjust the motor trimpot
  • Only adjust it enough to reliably read games and music CDs again. If the speed is too slow, the laser can physically "burn" your games or kill the laser.
  • Consider anything less then a 80-90% read rate a failure. These are hard to reliably recover.
  • Before starting, mark the original adjustment point and write down the factory setting as tested. It will be difficult to take it back to stock without this information.
  • Adjust the trimpot incrementally using a Phillips PH1 or other compatible bit. Do this until the laser is reading games more consistently.
Insertar traducción aquí
