Saltar al contenido principal
Inglés
Español
Paso 4
With the laser removed from the system, remove the 2 Phillips PH1 screws. Check if the laser is plastic. If the laser is plastic, it cannot be repaired and must be replaced. The example shown can be adjusted. If the laser is plastic, it cannot be repaired and must be replaced. The example shown can be adjusted.
Repair sanity check
  • With the laser removed from the system, remove the 2 Phillips PH1 screws. Check if the laser is plastic.
  • If the laser is plastic, it cannot be repaired and must be replaced. The example shown can be adjusted.
Insertar traducción aquí
