Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Before starting, make sure you have a die cast laser. Plastic lasers are not repairable.
Is your system recoverable?
  • Before starting, make sure you have a die cast laser. Plastic lasers are not repairable.
  • If your laser is plastic: You must replace the laser due to uneven wear.
  • If you have a Die cast laser, this fix may improve the read rate. However, this is an age based failure. Note: In some cases, the laser resistance will need to be adjusted.
Insertar traducción aquí
