Saltar al contenido principal
Inglés
Español
Paso 7
With the opening picks still inside the phone, lift the screen up toward you. Do not pull it off right away, but leave the screen at an angle. Put the screen down along with the opening picks in order to keep it loose. Heat up the bottom to loosen the adhesive from the back and the menu button. Carefully pull the screen  towards you.  Keep an eye on the bottom to make sure that the buttons are separating from the adhesive.
Removing screen
  • With the opening picks still inside the phone, lift the screen up toward you. Do not pull it off right away, but leave the screen at an angle.
  • Put the screen down along with the opening picks in order to keep it loose. Heat up the bottom to loosen the adhesive from the back and the menu button.
  • Carefully pull the screen towards you. Keep an eye on the bottom to make sure that the buttons are separating from the adhesive.
  • Be very careful when removing the button flex cables from the screen. If these cables are broken, you will need to replace the charging port assembly.
Insertar traducción aquí
