Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 13 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap. Make sure you are flipping up the retaining flap, not the socket itself.
  • Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
  • Make sure you are flipping up the retaining flap, not the socket itself.
  • Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
  • Remove the motherboard from the DS Lite.
  • Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
Insertar traducción aquí
