Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Twist the opening pick to fully dislodge the battery and remove it. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
  • Twist the opening pick to fully dislodge the battery and remove it.
  • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
  • To install a new battery and ensure that is is properly aligned:
  • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  • Lay the replacement battery in place, but do not apply adhesive yet. Resume re-assembly until the motherboard is in place (STEP 18).
  • Apply new pre-cut adhesive or double-sided tape onto the phone frame, around the perimeter of the battery compartment, but not in the rectangular cutout in the center (which is actually the back side of the display).
  • Temporarily connect the battery connector to the motherboard to ensure proper battery alignment.
  • Press the battery firmly into place for 5-10 seconds. Disconnect the battery and resume re-assembly.
Tuerce la púa de apertura para sacar la batería y removerla.
No reutilices la batería luego de haber sido removida, ya que esto es un riesgo de seguridad potencial. Reemplaza con una nueva batería.
Para instalar una batería nueva y asegurarte de que este correctamente alineada:
Remueve cualquier resto de adhesivo del teléfono y limpia las áreas pegadas con alcohol isopropílico y un paño anti-pelusa.
Coloca la batería de reemplazo en su lugar, pero no apliques el adhesivo todavía. Resume el re-ensamblaje hasta que la placa madre este en su lugar. (PASO 18)
Aplica el adhesivo pre-cortado o la cinta de doble cara sobre el marco del teléfono, alrededor del perímetro del compartimiento de la batería, pero no en el recorte rectangular en el centro (que en realidad es la parte trasera de la pantalla).
Temporalmenteconecta el conector de la batería a la placa madre para asegurarte de que la batería esté adecuadamente alineada.
Presiona la batería firmemente en su lugar durante 5-10 segundos. Desconecta la batería y sigue re-ensamblando.
