Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 5
Place a spudger on the left side of the speaker and your thumb and index finger on the right side. Use the spudger to push the speaker out from under the edge of the rear case. The adhesive on the speaker is very strong. Applying a steady, gentle force with the spudger is the best way to slowly loosen it.
  • Place a spudger on the left side of the speaker and your thumb and index finger on the right side.
  • Use the spudger to push the speaker out from under the edge of the rear case.
  • The adhesive on the speaker is very strong. Applying a steady, gentle force with the spudger is the best way to slowly loosen it.
Coloca un spudger por el lado izquierdo del altavoz y sujetar el lado derecho con los dedos pulgar e índice.
Utiliza un spudger para despegar el altavoz de la carcasa trasera.
El adhesivo bajo el altavoz es bastante fuerte. Aplica una fuerza constante con el spudger para poder quitarlo lentamente.
