Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 9
In the following steps, you will be separating the home button gasket from the iPad's front panel. This gasket is extremely delicate and can tear easily. If the gasket does not separate easily from the front panel, reapply heat using the iOpener before continuing. Use the pointed end of a spudger to gently pry the Home Button assembly up from the display. Use the pointed end of a spudger to gently pry the Home Button assembly up from the display.
  • In the following steps, you will be separating the home button gasket from the iPad's front panel. This gasket is extremely delicate and can tear easily. If the gasket does not separate easily from the front panel, reapply heat using the iOpener before continuing.
  • Use the pointed end of a spudger to gently pry the Home Button assembly up from the display.
Insertar traducción aquí
