Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 18 guías que incluyan este paso.
Inglés
Español
Paso 22
Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad. Be very careful to not insert the pick more than 2 mm below home button to avoid damaging the button. Be very careful to not insert the pick more than a quarter inch (6 mm) into either side of the home button to avoid damaging the display cables underneath.
  • Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
  • Be very careful to not insert the pick more than 2 mm below home button to avoid damaging the button.
  • Be very careful to not insert the pick more than a quarter inch (6 mm) into either side of the home button to avoid damaging the display cables underneath.
Desliza la púa de apertura izquierda a lo largo del borde inferior de la pantalla, luego quítala de la esquina derecha inferior del iPad.
Ten mucho cuidado de no insertar la púa más de un cuarto de pulgada (6 mm) dentro de la pantalla para evitar dañar el Botón de inicio y los cables de la pantalla que están debajo.
[* black] Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
-[* icon_caution] Be very careful to not insert the pick more than a quarter inch (6 mm) into the display to avoid damaging the Home Button and display cables underneath.
+[* icon_caution] Be very careful to not insert the pick more than 2 mm below home button to avoid damaging the button.
+[* icon_caution] Be very careful to not insert the pick more than a quarter inch (6 mm) into either side of the home button to avoid damaging the display cables underneath.
