Saltar al contenido principal
Inglés
Español
Paso 46
Remove 2 screws to remove the metal bar from the fuser. After removing one screw, this small circuit board can be removed. The board contains a beam interrupt sensor, which contains an infrared LED pointing at an infrared phototransistor. When an object enters the slot and breaks the beam, the phototransistor detects it as a drop in infrared light.
  • Remove 2 screws to remove the metal bar from the fuser.
  • After removing one screw, this small circuit board can be removed.
  • The board contains a beam interrupt sensor, which contains an infrared LED pointing at an infrared phototransistor. When an object enters the slot and breaks the beam, the phototransistor detects it as a drop in infrared light.
Insertar traducción aquí
