Saltar al contenido principal
Inglés
Español
Paso 45
After removing the plastic clip, the soft foam pressure roller can be removed. The metal rod in the roller allows the roller to be negatively charged, which prevents toner from sticking to the fusing film. Each end of the rod is coated in a conductive black liquid which helps it make contact with the high-voltage connector.
  • After removing the plastic clip, the soft foam pressure roller can be removed.
  • The metal rod in the roller allows the roller to be negatively charged, which prevents toner from sticking to the fusing film. Each end of the rod is coated in a conductive black liquid which helps it make contact with the high-voltage connector.
Insertar traducción aquí
