Saltar al contenido principal
Inglés
Español
Paso 13
After removing the cover and the clips holding in the lenses, the inside of the laser assembly can be seen. The chip on the motor board is an AN44010A, most likely some sort of brushless motor driver, although no datasheet could be found. The chip on the motor board is an AN44010A, most likely some sort of brushless motor driver, although no datasheet could be found.
  • After removing the cover and the clips holding in the lenses, the inside of the laser assembly can be seen.
  • The chip on the motor board is an AN44010A, most likely some sort of brushless motor driver, although no datasheet could be found.
Insertar traducción aquí
