Saltar al contenido principal
Inglés
Español
Paso 3
Now on to the formatter. Remove 2 screws on the I/O port cover. Remove 6 screws on the formatter cover.
Formatter Assembly
  • Now on to the formatter.
  • Remove 2 screws on the I/O port cover.
  • Remove 6 screws on the formatter cover.
  • Disconnect 3 connectors to the laser assembly, the cartridge connector, and the control panel.
  • Disconnect 2 flat flexible cables to the laser assembly and the control board.
  • While the service manual says not to use a PoziDriv screwdriver, I found that using a normal Phillips screwdriver on the screws in this printer would require excess force and damage the screws, but a PoziDriv screwdriver removed the screws without causing any damage.
Insertar traducción aquí
