Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin. Flip your device over so the bottom panel is facing up.
  • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
  • Flip your device over so the bottom panel is facing up.
  • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
Insertar traducción aquí
