Saltar al contenido principal
Inglés
Español
Traduciendo paso 3
Paso 3
With the hard drive and the metal case that encloses the hard drive removed from the laptop, you will see two screws on either side of the metal case. Remove these screws and lift the hard drive out of the metal casing. Set the hard drive to the side and slide a new hard drive to the metal casing, ensuring that the white label is on top.
  • With the hard drive and the metal case that encloses the hard drive removed from the laptop, you will see two screws on either side of the metal case. Remove these screws and lift the hard drive out of the metal casing.
  • Set the hard drive to the side and slide a new hard drive to the metal casing, ensuring that the white label is on top.
Insertar traducción aquí
