Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 18 guías que incluyen este paso.
Inglés
Holandés
Paso 3
While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step. As you follow the directions, take special care to avoid prying in the following areas: Home Button
  • While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
  • As you follow the directions, take special care to avoid prying in the following areas:
  • Home Button
  • Front Facing Camera
  • Main Camera
Onder verschillende delen van het glas bevinden zich kwetsbare onderdelen. Om te voorkomen dat je deze onderdelen beschadigt, verwarm en wrik je alleen in de gebieden die in elke stap worden beschreven.
Ga voorzichtig te werk en wrik niet in de volgende gebieden:
Thuisknop
Naar voren gerichte camera
Hoofdcamera
