Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Being careful not to rip any ribbon cables still connecting the two halves of the device, lay the display assembly flat so you can access the back of the home button. Use a plastic opening tool to pry the rubber membrane up from around the home button. Use a plastic opening tool to pry the rubber membrane up from around the home button.
  • Being careful not to rip any ribbon cables still connecting the two halves of the device, lay the display assembly flat so you can access the back of the home button.
  • Use a plastic opening tool to pry the rubber membrane up from around the home button.
Insertar traducción aquí
