Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 15
Paso 15
Remove the battery. Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
  • Remove the battery.
  • Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
  • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
  • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
  • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
  • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them last.
  • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
  • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
Verwijder de batterij.
Verwijder alle overgebleven lijmresten in de behuizing van je MacBook Pro voordat je je nieuwe batterij installeert.
Met een beetje geluk kun je alle kleefstrips er rustig met je vingers uit trekken.
Als dit niet lukt, kun je iedere sectie met lijm bevochtigen met wat lijmverwijderaar, waarna je deze in laat trekken gedurende ongeveer 2-3 minuten. Schraap de lijm er vervolgens uit met een openingsplectrum of een van de andere tools in je kit. Dit kan wat moeite kosten, dus wees geduldig.
Veeg mogelijk overgebleven lijmverwijderaar uit de laptop en geef je MacBook Pro wat tijd om te drogen.
De vervangende batterij in je kit wordt geleverd met vooraf geïnstalleerde kleefstrips. Test of de batterij past voordat je de beschermfolie eraf trekt. Als dit zo is, kun je de folie weghalen en de batterij stevig op z'n plek drukken. Als er nog extra folie op de batterij zit, haal je deze ook nu weg.
Kalibreer je vers geïnstalleerde batterij: laad deze op tot 100% en laat 'm nog minstens twee uur doorladen. Haal je laptop van de oplader en gebruik deze totdat deze zichzelf uitschakelt vanwege een lege batterij. Wacht 5 uur en laad je laptop nog een keer ononderbroken op tot 100%.
Als je onverwacht of vreemd gedrag in je laptop ziet, of je hebt problemen nadat je je nieuwe batterij hebt geïnstalleerd, kan het handig zijn de SMC van je MacBook Pro te resetten.
