Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 6
Paso 6
These shots show how the rubber fan gasket should be installed during reassembly. Be sure not to install the gasket underneath the ear where the end of the heatsink is screwed down to the upper case. Additionally, be sure the small post molded into the rubber gasket mates with the hole cut into the upper right corner of the logic board.
  • These shots show how the rubber fan gasket should be installed during reassembly. Be sure not to install the gasket underneath the ear where the end of the heatsink is screwed down to the upper case.
  • Additionally, be sure the small post molded into the rubber gasket mates with the hole cut into the upper right corner of the logic board.
Estas fotos muestran cómo se debe instalar la junta del ventilador de goma durante el reensamblaje. Asegúrese de no instalar la junta debajo de la oreja donde el extremo del disipador está atornillado a la carcasa superior.
Además, asegúrese de que el pequeño poste moldeado en la junta de goma se acopla con el orificio cortado en la esquina superior derecha de la placa lógica.
