Inglés
Español
Paso 4
If the heat sink seems to be stuck to the logic board after removing all eight screws, use a spudger to carefully separate the heat sink from the faces of the CPU and GPU. Remove the heat sink from the logic board.
  • If the heat sink seems to be stuck to the logic board after removing all eight screws, use a spudger to carefully separate the heat sink from the faces of the CPU and GPU.
  • Remove the heat sink from the logic board.
  • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
Si el disipador de calor parece estar pegado a la placa lógica después de quitar los ocho tornillos, use un spudger para separar cuidadosamente el disipador de calor de las caras de la CPU y la GPU.
Retire el disipador de calor de la placa lógica.
Al volver a instalar el disipador de calor, asegúrese de aplicar una nueva capa de pasta térmica. Si nunca antes ha aplicado pasta térmica, tenemos una guía que lo hace fácil.
