Saltar al contenido principal
Inglés
Español
Paso 4
Now we come to the mixing process. First figure how much resin you are going to need to adequately cover the cloth piece with a little to spare to pre-dab the dinged area. Add Filler, it helps to make the solution less watery and more workable
  • Now we come to the mixing process.
  • First figure how much resin you are going to need to adequately cover the cloth piece with a little to spare to pre-dab the dinged area.
  • Add Filler, it helps to make the solution less watery and more workable
  • Then add the hardener; you only need a little and it really depends on the temp. Your box should say what is appropriate for your particular weather.
Insertar traducción aquí
