Saltar al contenido principal
Inglés
Español
Traduciendo paso 16
Paso 16
Remove the 4.2 mm Phillips screw that secures the white plastic bracket to the lens assembly. Lift the bracket off the lens assembly.
  • Remove the 4.2 mm Phillips screw that secures the white plastic bracket to the lens assembly.
  • Lift the bracket off the lens assembly.
  • If you are going to install a new lens, make sure to transfer the white plastic bracket and screw to the new laser lens before installation.
Insertar traducción aquí
