Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 6
If you didn't perfectly align the adhesive with the panel, use an X-Acto knife to trim away the edges. This will only fix minor misalignments. If you have to trim off more than half the adhesive strip, you should remove the tape and start over. This will only fix minor misalignments. If you have to trim off more than half the adhesive strip, you should remove the tape and start over.
  • If you didn't perfectly align the adhesive with the panel, use an X-Acto knife to trim away the edges.
  • This will only fix minor misalignments. If you have to trim off more than half the adhesive strip, you should remove the tape and start over.
Si no alineó perfectamente el adhesivo con el panel, use una cuchilla X-Acto para recortar los bordes.
Esto solo solucionará desajustes menores. Si tiene que recortar más de la mitad de la tira adhesiva, debe retirar la cinta y empezar de nuevo.
