Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 5
We recommend that you clean the exposed surface of the board with a soft cloth or sponge and a small amount of rubbing alcohol.
  • We recommend that you clean the exposed surface of the board with a soft cloth or sponge and a small amount of rubbing alcohol.
  • Melt a small solder bead directly onto the metal connector on the board by placing the soldering iron onto the metal connector and then pressing solder against the tip and the board.
  • Once a small amount of solder has melted onto the board, lift the solder away first and then the soldering iron.
Insertar traducción aquí
