Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
Top part of the check valve on the bottom. there is a fine screen that acts as a filter. Remove that by removing the three Phillips screws with a long #2 Phillips screwdriver. Clean the screen under running water with a brush. Reassemble after proper cleaning. Next step is to remove the top cover to get to the water supply to the K-cup.  Open the Keurig. remove two Phillips screws that hold it in place. Lift the top cover up and forward to remove it.
  • Top part of the check valve on the bottom. there is a fine screen that acts as a filter. Remove that by removing the three Phillips screws with a long #2 Phillips screwdriver. Clean the screen under running water with a brush. Reassemble after proper cleaning.
  • Next step is to remove the top cover to get to the water supply to the K-cup. Open the Keurig. remove two Phillips screws that hold it in place.
  • Lift the top cover up and forward to remove it.
En el interior de dicha válvula se encuentra un malla pequeña que hace la función de filtro. Puedes removerlo destornillando los tres tornillos con un destornillador Phillips largo #2. Limpia la malla con agua limpia y un cepillo. Reensambla la valvula después de haber limpiado perfectamente el filtro.
El siguiente paso es remover la tapa superior de la cafetera para tener acceso a la entrada de agua del porta cápsulas. Para eso hay que remover los dos tornillos Phillips que la aseguran en su lugar.
Levanta la tapa súper y tira de ella para removerla de su lugar.
