Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Orient the display frame so the home button connector faces you. Use the pointed edge of the spudger to separate the home button ribbon cable from the display frame. Be careful when removing the home button ribbon cable. It is delicate and can tear easily.
  • Orient the display frame so the home button connector faces you.
  • Use the pointed edge of the spudger to separate the home button ribbon cable from the display frame.
  • Be careful when removing the home button ribbon cable. It is delicate and can tear easily.
Insertar traducción aquí
