Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 25 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive. If your glass is shattered, put packing tape over the entire panel to hold it together during the removal process.
  • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
  • If your glass is shattered, put packing tape over the entire panel to hold it together during the removal process.
  • Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
  • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
  • Shift the iOpener to heat the remaining section of the panel for another two minutes.
  • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
Abrir tu teléfono comprometerá los los sellos impermeables. Ten preparado adhesivo de reemplazo antes de proceder o ten cuidado para evitar exposición al líquido si vuelves a ensamblar tu teléfono sin reemplazar el adhesivo.
Si tu vidrio está hecho pedazos, coloca cinta de embalaje sobre todo el panel para mantenerlo unido durante el proceso de eliminación.
Coloca el iOpener caliente sobre el panel trasero durante dos minutos para soltar el adhesivo alrededor del borde del cristal.
Necesitarás volver a calentar y aplicar el iOpener varias veces para alcanzar la temperatura suficiente. Consulta las instrucciones del iOpener para evitar sobrecalentamiento del dispositivo.
Mueve el iOpener para calentar la sección restante del panel durante dos minutos.
También se puede utilizar un secador de pelo, pistola de calor, o lámina caliente, pero ten cuidado de no sobre calentar el móvil -la pantalla OLED y la batería interna son susceptibles a daño por calor.
