Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 25 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
To install new rear glass: Use tweezers to peel away any remaining adhesive from the phone's chassis.
  • To install new rear glass:
  • Use tweezers to peel away any remaining adhesive from the phone's chassis.
  • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
  • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
  • If you're reinstalling the old rear glass, or using rear glass without adhesive pre-installed, follow this guide.
Usa pinzas para despegar cualquier adhesivo restante de cristal trasero y el chasis del teléfono.
Luego, limpia las áreas de adhesión con alcohol isopropólico de concentración alta ( al menos 90%) y un paño anti-pelusa. Desliza en una dirección solamente, no desde atrás hacia adelante. Esto ayudará a preparar la superficie para un adhesivo nuevo.
Siga esta guía para volver a instalar el cristal trasero.
[* icon_reminder] To install new rear glass:
black] Use tweezers to peel away any remaining adhesive from both the rear glass and the phone's chassis.
black] Then, cleanClean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
[* black] Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
[* icon_reminder] Follow [guide|47490|this guide] to reinstallIf you're reinstalling the old rear glassglass, or using rear glass without adhesive pre-installed, follow [guide|47490|this guide|new_window=true].
