Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 7
Connect the wires. The plugs are polar sensitive, so if it doesn't light up, you will need to flip it 180 degrees.  You'll need to wire them up in parallel and use some electrical tape so they maintain a parallel wiring. Tape the wire harness onto the reinforcement beam.
  • Connect the wires. The plugs are polar sensitive, so if it doesn't light up, you will need to flip it 180 degrees. You'll need to wire them up in parallel and use some electrical tape so they maintain a parallel wiring.
  • Tape the wire harness onto the reinforcement beam.
Insertar traducción aquí
