Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Lift off the metal base, revealing the hard drive.
  • Lift off the metal base, revealing the hard drive.
  • Disconnect the ATA hard drive cable from the right side of the logic board. Try to pull straight up so you don't bend the pins on the hard drive.
  • The hard drive is mounted on the baseplate of the unit. It is a 40 GB 2.5" Fujitsu ATA drive (NOT an SATA drive). You can replace this drive with a standard ATA laptop drive if you want to upgrade it.
Insertar traducción aquí
