Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket. Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
  • Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
  • Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
Insertar traducción aquí
