Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
If you're installing a new front panel assembly, it may need the following preparation: Peel the plastic strips covering the adhesive around the perimeter of the front panel assembly.
  • If you're installing a new front panel assembly, it may need the following preparation:
  • Peel the plastic strips covering the adhesive around the perimeter of the front panel assembly.
  • Remove the small piece of adhesive backing from the digitizer cable.
  • Make sure all copper is covered on the new replacement screen as once fitted without this the screen will move randomly.
Insertar traducción aquí
