Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Español
Paso 2
Gently place an opening pick in the corner of the gap between the bottom casing and rear case. Slide the opening pick along the side of the casing, prying it away from the adhesive as you go. Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
  • Gently place an opening pick in the corner of the gap between the bottom casing and rear case.
  • Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
Insertar traducción aquí
