Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Insert a microSD card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone above the volume buttons. Press to eject the tray. This may require a significant amount of force.
  • Insert a microSD card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone above the volume buttons.
  • Press to eject the tray.
  • This may require a significant amount of force.
  • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray. The connectors should be inserted first and away from you (if the display was face up).
  • It is normal, that the microSD card doesn't sit perfectly within the trey. It is also very simple to place it correctly flat inside the tray.
Insertar traducción aquí
