Saltar al contenido principal
Inglés
Español
Paso 12
Pull the circuit boards loose from the bottom plate. You may need to use a spudger to pry the circuit free. The mouse cable is glued to the bottom plate, so do not quickly yank the circuit boards away.
  • Pull the circuit boards loose from the bottom plate.
  • You may need to use a spudger to pry the circuit free.
  • The mouse cable is glued to the bottom plate, so do not quickly yank the circuit boards away.
  • The circuit boards are not very strongly attached to each other; do not pull hard on the top board or they may separate, damaging the device.
Insertar traducción aquí
