Saltar al contenido principal
Inglés
Español
Paso 3
Remove the two Phillips #000 screws securing the power button bracket to the outer case. Take extra care with the display cables, which can prevent easy access to the right-hand screw. The cables are easily damaged.
  • Remove the two Phillips #000 screws securing the power button bracket to the outer case.
  • Take extra care with the display cables, which can prevent easy access to the right-hand screw. The cables are easily damaged.
  • Carefully pull the power button bracket up and out of the outer case.
  • This bracket is made of cast aluminum and is very easily cracked. Proceed with caution.
Insertar traducción aquí
