Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 4
This step is only if you want to replace the micro USB port flex cable. Remove the two screws and disconnect the charging port flex cable from the main board. Use a plastic tool to unstick the flex cable from the middle frame.
Micro USB Charging Port / Dock with Flex Cable
  • This step is only if you want to replace the micro USB port flex cable.
  • Remove the two screws and disconnect the charging port flex cable from the main board.
  • Use a plastic tool to unstick the flex cable from the middle frame.
Insertar traducción aquí
