Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 2
Disconnect the front panel ribbon cable by gently pulling it straight up. Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard. Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
  • Disconnect the front panel ribbon cable by gently pulling it straight up.
  • Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard.
  • Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
Desconecte el cable plano del panel frontal tirando suavemente hacia arriba.
Desconecte el cable plano del disco duro tirando suavemente de la pestaña azul de la placa base.
Desconecte el cable plano de la unidad óptica tirando suavemente de la lengüeta anaranjada de la placa base.
