Saltar al contenido principal
Inglés
Español
Paso 7
Access to the circuit board with the wire terminals is by removing the plate with 2 smaller solder points almost at the corners of the shielding plate. Keeping the 2 solder points hot, work a flat bladed knife carefully between the shielding plate and connector so as to not cut the wires underneath until the plate releases.
Removing the shielding plate
  • Access to the circuit board with the wire terminals is by removing the plate with 2 smaller solder points almost at the corners of the shielding plate.
  • Keeping the 2 solder points hot, work a flat bladed knife carefully between the shielding plate and connector so as to not cut the wires underneath until the plate releases.
El acceso a la placa de circuito con los terminales de cable es mediante la eliminación de la placa con 2 puntos de soldadura más pequeños casi en las esquinas de la placa de protección.
Manteniendo calientes los 2 puntos de soldadura, trabaje con cuidado una cuchilla plana entre la placa de protección y el conector para no cortar los cables por debajo hasta que se libere la placa.
